Sawing and Drying
Subject:
kiln drying old heart pine
3/28/17
Bruce Bishop Member
Greetings, I have pine wood about 150 years old and a new kiln dryer we built. I am more worried about killing bugs than drying (although maybe I should be worried about both). I was advised to stick the wood in and set the temp at 150 and run for six hours. Does this sound like good advice? Do not want to make a mistake, have a project to get done, thanks!
3/28/17       #3: kiln drying old heart pine ...
Tennessee Tim
Just a few questions that will help with answering your question. Yes with it being heart pine I'd be concerned NOT to damage what can't be replaced.
1) you mentioned built a kiln....now that's several types and styles with also pure tried experimental as my DH kiln, to kits from nyle and other kiln makers as to you buy the kit or parts and use their plan...so is your kiln strictly a homemade with your plans...a university plan...someone as Timbergreen that are proven....or professional as Nyle.
2) what heat source for the sterilizing are you using??
3) what style/type of metering are you using???
4) and where did you get your sterilizing time schedule???
IF your lumber has stayed dry not out in the weather/rain you may be able just to sterilize/heat BUT you need to consider the final product market....IF it's going to be used as flooring it may need to be kilned to get the MC correct for install and use....nothing worse than installing flooring at improper MC and it shrinks or bucks.
The lumber will need to be stickered to sterilize or dry to get even temps throughout.
Good luck with your project...Dr. Gene should have the best numbers and advise you may need.
3/29/17       #5: kiln drying old heart pine ...
Bruce Bishop Member
Thanks Tim, it is a 4'X4'X10' plywood with a 4 inch shell if r24 insulation and vapor barrier. We have an external heat coil and fan that is ducted in at either end and circulates the air like a warm air conditioner. The wood is for a table top. Thanks!
3/30/17       #6: kiln drying old heart pine ...
Gene Wengert-WoodDoc
The thicker the wood, the longer you need. Start the clock when you reach 150 F, not before. The time for 1" with good air flow could be six hours, but 2" needs closer to 18 hours. For certification, you actually need to measure core temperatures and be 100% certain that all pieces reached 133 F inside.
