Sawing and Drying
Subject:
Moisture reabsorbtion
3/30/17
Anna Member
I have some lengths of European Oak at a MC of 9% and want to increase it to EMC ~18%. If it's put outside what has to be done to reduce the risk of warping, cracks etc? Thanks
3/30/17       #2: Moisture reabsorbtion ...
Very curious why you want to increase the moisture content. Can't imagine a case where raw wood cracked from swelling.
3/30/17       #3: Moisture reabsorbtion ...
Gene Wengert - WoodDoc
It depends on the grain of the piece, so we cannot say how many will be affected.
It is virtually impossible to do what you want. You should perhaps try exposing the wood to 95%RH and 120 F. The humidity will increase the moisture and the heat makes it go quickly and deeply.
3/31/17       #4: Moisture reabsorbtion ...
Anna Member
Thanks for your responses. It's mixed grain.
We have it already, but want to change it's use from inside flooring to outside decking. I understand that it's a waste of money to dry timber and then want to increase the MC, but it's left over.
Could you please tell me why it would be virtually impossible? I was thinking maybe the cell walls would be damaged from the bound water being extracted during drying.
We don't have access to equipment to raise humidity or temp. We were hoping it would reach EMC by itself.
3/31/17       #5: Moisture reabsorbtion ...
Gene Wengert-WoodDoc
If you use oak for a deck, it will have crease to 12% MC on the average, if not exposed to rain or other wetting. If wetted, then it can go much higher. After the rain, it will dry and that will result in surface checking that will get worse with each wetting and drying cycle. Because oak moves so much with wetting and drying, you need to nail or screw with only one fastener per width, so it can move without breaking a fastener. Plus, you need to allow adequate room for swelling. Oak is seldom used for decking as it's appearance is not consider good, cracks between pieces can be quite large if there is no rain for a while, and some cupping is likely when dry. Ends splits are also likely.
3/31/17       #6: Moisture reabsorbtion ...
Is there such a thing as EMC in an outdoor installation? I suppose there is, but it will change with fog, rain, snow, drought. So in my mind, EMC is not a goal since it can swing during the day. Maybe even an hourly goal? EMC is usually a term used on the acclimation of kiln dried wood used indoors. Indoors where the conditions are varied only as much as the air conditioning changes.
3/31/17       #7: Moisture reabsorbtion ...
We do indeed have an outside EMC if the wood is protected from rain...often 12-13% EMC.
4/1/17       #8: Moisture reabsorbtion ...
Incidentally EMC refers to air. So the air is at 12% EMC.
4/2/17       #9: Moisture reabsorbtion ...
The EMC for outdoors is based on the average outside humidity. The EMC does indeed vary from very humid before sunrise and when raining or foggy (28% EMC) to quite dry in the afternoon (6% EMC), but the average is often close to 12 - 13% EMC. Based on weather records, outside EMC can be determined monthly (wood is not exposed to direct sun or rain). See the booklet "EMC in outdoor locations...."
www.woodweb.com/knowledge_base_images/zp/equilibrium_moisture_content.pdf
4/2/17       #10: Moisture reabsorbtion ...
Here is the link for outdoor EMC
Outdoor EMC
