Sawing and Drying
Subject:
chainsaw bar length
8/16/17
al magrum Member
what is the max bar you can run on a 80 cc chainsaw? its a echo 800 the book says 36
can you run 40" for ripping on a 36" diameter log
thanks
AL
8/18/17       #3: chainsaw bar length ...
Keith Newton
If your not using a skip-tooth chain, then you shouldn't have a problem going longer with a skiptooth since there will be fewer teeth making the cut.
