Sawing and Drying
Subject:
Listening to your Saw
1/2/18
John G Member
I have always been able to listen to the saw I have been using to hear abnormalities with the equipment even with adequate hearing protection. Just a slight change in noise can illuminate a significant issue that might not be caught until too late. Blade changes as a basic example.
We have created a guideline to determine when to change blades based on material or next material to be cut, but being able to hear subtle variations in the equipment helps.
We have installed an large grinder on our beam saw which has severely reduced our ability to hear the saw running.
Has anyone else had this issue and found a solution or do I just move on and use the hard data we retrieve from the saw?
Thanks,
John
1/2/18       #2: Listening to your Saw ...
GeneWengert-WoodDoc
I have seen many high speed mills that listen to their saws electronically and even show a picture on a screen of the vibrations. There is a large bit of data about saw vibration...basically, we want a saw to have a high resonant frequency to avoid getting close to its resonant frequency. There is a lot we do to get the high frequency for the saw, including tensioning, which is done by rolling and hammering. One special trick is heating the eye or center, and cooling the tooth region or rim. This is also why we often see that most saws are designed for a specific rpm.
