Sawing and Drying
Subject:
killing bugs in beams with heat.
3/6/18
Jonathan Cook Member
I have beams SY pine 8x6,8x8, 8x10 and some cants that are larger that I plan to re-saw as I noticed some of the ones I cut years ago have twisted so I started cutting them over sized. I plan to re-saw them and stack them on a trailer and take them to a shop to have a timber frame cut from them. I wasn't planning on kiln drying them, but thought maybe I should heat them to kill any boring beetles that might be in them. Years ago when I was building my present house I put oak and maple 1 inch boards that I used for trim and my stairway on a flatbed trailer and put it in the sun with clear plastic over it with a torpedo heater. It seamed to work fine because I did not see any sign of bugs in my wood work. But with large beams how long would I have to maintain what temperature to kill any bugs that might be in my beams. Also Do I need to heat them before I re-saw them in case the heat makes them warp or twist.Most of them have air dried for years. Will be more work to load them on the trailer heat them unload them cut them and then reload them. Or should I just put a finish on the wood and figure it wont get re infested after the first cycle of larva. No one kiln dried lumber in the old days.
3/7/18       #2: killing bugs in beams with heat. ...
Gene Wengert-WoodDoc
What causes warp, including cup and twist, is a change in moisture content. So, if you pieces are not at equilibrium with their environment, they will change MC, and with syp, they are likely to warp a little bit. The moisture change determines how much warp...small change means little warp.
I do not know how long it will take to get the interior of the beam to 133 F. It depends on how hot the air temperature is. Plus, dry wood is an excellent insulator, so that will add time as well. As a general rule, if 1” takes six hours, then 2” takes 15 hours, 4” takes 1.5 days, and 8” takes 4 days.
