Sawing and Drying
Subject:
Dry 3 Inch Red Oak
3/29/19
Walter Member
I am having a huge red oak milled into 3 inch live sawn slabs. Lumber will be used for table tops etc. How long will this need to AD? And what about KDing? Thanks
3/29/19       #2: Dry 3 Inch Red Oak ...
DONALD LEWIS
Air drying could do a lot of damage if not done carefully. It is safer to put in a well designed kiln right away and dry very slowly.
3/29/19       #3: Dry 3 Inch Red Oak ...
I'd be looking for a good vacuum kiln guy with those. Go directly from the log to the vacuum kiln and greatly reduce degrade.
4/1/19       #4: Dry 3 Inch Red Oak ...
Gene Wengert-Wood Doc
Vacuum is a good idea. Otherwise, you could easily ruin 12/4 oak. Because air drying will take a year, consider the option of cutting thinner. Note that an oak table that is 3’ x 8’ x 3” will weigh 170 pounds without the legs. This might be a bit heavy for many people.
