Sawing and Drying
cutting
2/24/14
Bill Member
Any Advice,
I have some white and red oak 10 x 10 timbers that I want to make a bar top out of. They were cut last summer and air dried since then. What would happen if I cut them 1 1/2 in. finished them and put a sealer on them? They are for myself so don't care if they crack as they dry. What type of finish would be a good top coat?
2/24/14       #2: cutting ...
EC Aumiller Member
After you cut them, they need to be equalized because the moisture content in center is probably different than outside..
Recommend cutting them and stickering them long enough to stabilize to prevent twisting / warping / bowing / etc...
If you do not want to kiln dry them after cutting, stack in a climate controlled area..
2/25/14       #3: cutting ...
Dave Boyt
Cracking won't be your biggest problem. You will very likely have at least 5% shrinkage (1/2" in width, 3/16" thickness. A 10x10 will not be air dry after one year, so your idea of resawing it is good. Then, as EC says, finish drying them. Not all finishes stand up to alcohol, so that would probably be your first concern. Good luck!
