Sawing and Drying
Air Drying Cypress
5/13/14
Dwight Farris
I plan to install 1-1/8" thick by 10" wide cypress boards (board and batten style), on the exterior of my shop. The mill is air drying for 30 days. My question: what moisture content do they need to install on exterior.
Thank you!
5/14/14       #2: Air Drying Cypress ...
Dave Boyt  Member
Dwight, the beauty of board & batten is that moisture content doesn't matter! I've cut down a tree, milled it, and nailed up the boards all in the same day. The battens cover the cracks that develop as the boards dry. Two pieces of advice: use only one nail centered width-wise on the boards, so they'll be free to shrink around the nail without splitting. It also helps to nail with the side of the board that was closer to the center of the tree to the outside of the structure. That way, it pushes against the nail as it tries to cup. Wait a couple of weeks (or longer) to put up the battens.
    • Forestry.com
