Sawing and Drying
Wood fired kiln
6/9/14
J.S. Member
I have a 3000 bf kiln with Nyle dh system stuck a large wood burning furnace on back, just heating outside air and blowing thru kiln exhaust out vents, works great on the well air dried lumber that is run thru, however I have trouble reaching 130+ degrees f for insect kill, I know that I need recirculation through the furnace, does anyone have control system or something simple for wood fired kilns? Any information would be appreciated.
6/10/14       #2: Wood fired kiln ...
Gene Wengert-Wood Doc
Do you mean that the kiln is part of the chimney? In a house, there is a plenum, so the flue gasses go up the chimney to the outside. A fan takes the hot air in the plenum, which is separated from the flue, and recirculates this hot air. Why can' thou do the same?
6/10/14       #3: Wood fired kiln ...
J.S. Member
The flue gasses go out an external chimney, what I have is a residential type wood burner with a plenum to connect to a home's duct system, it has a fan that kicks on when the plenum reaches 100 deg F or so. The circulation fans in the kiln run as normal, I'm just blowing wood heated outside air into the chamber and exhausting out the vents, I know that this is wasteful of heat but am just burning slab wood from sawing operation and when the fire lays down, the furnace fan shuts off and heat in the chamber is circulated by the kiln fans. The only problem is that I cannot consistently build and hold the 130deg F + temp in the chamber. I'm certain if I regenerate kiln heat through the wood burner that it will build to oven like temps, like most wood heat systems, the problem is control, any suggestions?
6/10/14       #4: Wood fired kiln ...
Tennessee Tim
Website: http://tsmfarms.com
The outdoor wood burner boiler is the ideal system aka "southern boiler" and many others. It is a style used in a lot of lumber kilns that burn their chips and scraps.
To do what I think your asking gets a little tricky due to cresote build up in the "no contact" chamber for the higher temps needed. Your main objective is to recirculate the heated interior air when debugging. There are dampers made for controlling temps but I'm not familiar enough to suggest types or companies.
You may contact nyle due to they offer different heating source kilns.
Keep us posted...sounds like a fun project!!
Have a Blessed evening,
Tim
6/14/14       #5: Wood fired kiln ...
Robert Wimmer  Member
Website: http://customsawyer.com
I have a large Taylor outdoor wood burning boiler furnace that I circulate water through my house for heat. It is large enough to heat a pool or couple houses. It keeps the water temperature at a constant 180 degrees. I plan to use this to run a kiln in the future. I think the boiler holds over 300 gallons of water and it works super.
