Sawing and Drying
White oak logs
7/3/14
Ken Culbertson
Have a friend who has several 12' white oak logs that he felled last November and did put Anchor Seal on the ends. Now the logs are splitting on the ends of course and he says that they are not longer good for sawing into lumber. I say that they are, but would lose some at the ends. So what is accurate?
7/3/14       #2: White oak logs ...
Nick Holeman
I have cut logs much older than that and they still had plenty of good wood in them. You may have some of the outside of the wood that has some sap rot in it, but other than that, it should still be good. Whoever the sawyer is needs to know how to place the splits so he can cut the best lumber for you, if possible, rolling the logs to where the splits are at a diagonal so they can be edged out of the lumber. White Oak holds up good, and there still should be a lot of good useable lumber in there. I hope it goes well for you all. God bless.
7/4/14       #3: White oak logs ...
Brian
I agree with Nick. I have sawn many logs "too late" and have come up with plenty of good lumber for the effort. Oak is notorious for checking and such, need to get what you can. I'd suggest making sure the splits do not run down the sides of the log, but I pretty much ignore end checks now. I figure anything I'm going to use will have the ends cut off anyway; the checking/cracking during the drying session can give aid on how to use a given piece. Good luck with it.
7/4/14       #4: White oak logs ...
Ken Culbertson
Thanks guys, that's what I had understood and will pass it on to my friend.
