Sawing and Drying
I found a maket for my lumber,RR ties
8/12/14
Rod Hays
The 7x9 $25.7x8 $21 and the 6x8 are $20. Doesn't sound to bad on prices. I came up with an idea that I'll cut a few Beech trees and see how things go. I believe I can get 5 ties out of a 24'' dim log. 4- 6x8's on the outside and a 7x9 in the center. And no,they don't have to be a boxed center. I'm sure someone else has thought or done this,but I just don't no who. Anyway I'll see if my plan will works. Figure this might be a way to get rid of a few Beech trees and make a little $ along the way.
8/19/14       #2: I found a maket for my lumber,RR ti ...
Dave Boyt  Member
Rod, good to see that you are progressing with your mill. The RR tie market is pretty good, but look at it this way; a 7 x 9 x 8' log is 42 board feet, so you are being paid about $.50 per board foot. True, there is less cutting for a tie than for 1" thick boards, but you also have to handle the tie. Around here, ties must be bundled in groups of 10 or 20. Then you have to haul them to the nearest buying yard. Been there, done that, and moved on. If you don't have the equipment to handle the ties, the only person who makes money on the deal will be your chiropractor. Good luck, if you try it.
8/19/14       #3: I found a maket for my lumber,RR ti ...
Rod Hays
Well David, I have considered those things you speek of, but I still have not found a good outlet for Beech. You are right,they are very heavy and I don't have any equipment to move them. Here they don't have to be banded. I cut a few and tried moving a few onto the trailer and in wasn't to bad for a 150 pound 65 year old guy to do. I figure 50 cents a board foot for lumber you can't sale is a good deal for me. Thats way more then cutting the tree into firewood. The slaps I'll cut up for firewood though.
