Sawing and Drying
sent 6 blades off for resharp
8/15/14
Rod Hays
When they came back there was only 5 blades,said one they coundn't do nothing with. I tried the resharp blades and they didn't cut or last any longer then what i can do. They didn't seem to be as sharp as the ones i sharpen. and these blades were sharpned by a big name company. i'm saying all this that you can sharpen blades just as good or better then a resharp company can.
8/17/14       #2: sent 6 blades off for resharp ...
I sharpen my own but can in no way do it as cheaply as a service can. Time is money.
Find a different service.
8/17/14       #3: sent 6 blades off for resharp ...
Rod Hays
I can sharpen a blade a lot faster then having to roll them up,put them in a box and ship them off. Thats a lot of work and time spend for nothing,plus all the cost involved. The company I sent them to was highly recommended by everyone as one of the greatest resharp facilities.
8/17/14       #4: sent 6 blades off for resharp ...
Maybe if your just sharpening the tooth face but there is likely no way you can beat a machine that grinds the entire tooth profile AND gullet and then having to set. Its just not possibl when your having to address each tooth one at a time.
8/17/14       #5: sent 6 blades off for resharp ...
Rod Hays
That could be true,but my blades cut better than theres after resharp, and then the money lost from spending on shipping and then add the cost of them resharping equels a loss and nothing gained. Maybe I just to picky when it comes to having something sharp.
8/18/14       #6: sent 6 blades off for resharp ...
Agreed that I also seem to get my blades sharper than new however I have never taken the time to compare my output with a group of blades Ive sharpened as compared to a group brand new blades. My guess is the new blades (equivalent to having blades sharpened), while they may be (or seem) a bit less sharp, may actually perform better for longer.
It may not seem like it, but just like sharpening anything, tooth/edge geometry and the accuracy of the set has a tremendous effect on performance and the life of the cutting edge. Just like a chisel, you can sharpen it to a razor edge which will be very sharp but very fragile or you can sacrifice a bit of edge for a stronger cutting edge that will hold much longer. Hook angle could be slightly steeper when you sharpen your own, who knows. Accurate setting (I know my set is not as accurate as a new blade) also has a major effect in that some teeth will be working harder while others not at all.
My point is simply the same as always, even if your blades are "slightly" less sharp, which Im sure is an issue you can work out with your sharpening service, if you apply $25-$35 per hour to the time you have invested in making the sharpener, and the setter, and the time you have invested in standing there sharpening blade (at which time, no logs are being sawn), the sharpening service is likely still the smarter choice give that you have to address each tooth one at a time. Its a very slow process.
This of course all only applies if your looking at your work for profit as opposed to a hobby where you devalue your labor to zero.
8/18/14       #7: sent 6 blades off for resharp ...
Rod Hays
My blades cut better lumber and last longer and I can cut faster. I have no idea what the difference is on theirs verse mine, I sharpen blades when there are no logs to cut, in my spare time. The sharpener and setter might of took maybe 4 hours to build,so at 25 dollars an hour thats $100. Shipping and cost of sharpening was about 14 dollars each,not counting the time I had to spend packaging the blades and shipping off,and the time waiting then I had to un-package them. So I would add an hours worth of work packing and un-packing to the cost of resharp. Also most of the time I resharp my blades right on the mill so I'm not wasting time taking the blade off and then time put the blade back on. Also if you have to send blades off to resharp you have to have a bigger inventory of blades.
8/18/14       #8: sent 6 blades off for resharp ...
"I sharpen blades when there are no logs to cut, in my spare time"
The hobby/business factor. In business there is no spare time. All hours are billable.
And again, your not comparing apples to apples. Sharpening your blades on the mill is an unfair comparison to removing the blades, possibly having to clean them, set, then sharpen. Its a difference anyone would know before they even sent off to a sharpening service so its a "rigged" comparison. Sitting and touching up a blade with a dremel or a grinder on the mill is not re-sharpening. Its perfectly fine to do but its not a valid comparison to what happens to a blade sent off for sharpening.
I regularly time my own sharpening because its a process I find obnoxious and would much rather avoid. That said I have an automatic sharpener so I load the blade and walk away and either clean/set the next blade, clean the shop, do something else, while the blade is being sharpened. That said, at my fastest, I can fully set and sharpen about 5 blades an hour MAX. Only 4+ will come off the sharpener but several extras will already be set and clean ready to go. At $50/hr (my lowest shop rate) thats $10 per blade plus the cost of consumables and my investment in the sharpener. With that I am slightly (and I mean slightly) ahead of sending them out for sharpening. I dont doubt for a minute that I could find a sharpening service that would sharpen my blades to my satisfaction.
Anyone can choose to do anything they wish, but in my business there is no "spare time". If I am working in my business I am damn sure going to be paid for it. All hours are billable hours. The concept of "spare time" is a slippery slope. Its like thinking just because you got through a month and paid your bills your "making money".
8/18/14       #9: sent 6 blades off for resharp ...
Rod Hays
I believe sharpening on the mill is a fair comparison. I may not set the teeth,but the blade will cut without making waves in the lumber plus you can get back up to speed on cutting... As for the "spare time",it all depends on how efficient you are doing what ever you are doing. One people might be able to do something in an hour while another person will take 2 hours or more. I'm not sure how long the person charging twice as much will stay in business on billing by the hour. I've had a few jobs in my life that I was paid by the hour, and I had ''spare time'' then. I understand there is 480 minutes in an 8 hour day,but most people don't work efficient all those minutes. As Bill Gates dad would ask his son Bill,''what are you doing'?'' Bill would reply,''I'm thinking''. My point is that ''spar time'' can make a person rich is they are using their spark time wisely.
8/18/14       #10: sent 6 blades off for resharp ...
Sharpening on the mill is in no way a fair comparison. That would be like saying that I can sharpen a $200 14" carbide ATB saw blade on the saw just as effectively with a dremel tool and a diamond bit from home depot as compared to a professional sharpening service with a computerized sharpener. Its simply not possible.
Can I sit at a TV tray in front of the television at night while Im munching on some cheetos and "re-touch" a blade with a dremel? Sure can. But its in no way the same as having the blade professionally sharpened.
There is one immutable fact. When people do things themselves, build their own gadgets and gee gaws, they make great accommodations (excuses) for the short comings of their end product. We all do it. They can often live in a world of delusion thinking that they saved a fortune, or that it didnt really cost them anything because they had this stuff laying around, or it really doesnt matter because "all that was just scraps anyway". All the while it cost them ten fold in time and energy and they worked for pennies on the dollar for something that will require endless tending and tweaking and live a very short life.
Its still good work but the simple fact is, you can not build a truck for what you can buy one for right?. To think you could, and be profitable, would require you to lie to yourself about the countless hours, trips to the store, fuel, time, research, ancillary equipment, and so on, that we conveniently leave out of the mathematics of what it actually cost. Not to mention that the truck would require endless repairs, be broken down, need to be tweaked, would only be able to be driven by one driver who knows all the problems and work arounds, and so on. "oh, dont look at that, you gotta pull this lever, shove over here, hit this with a hammer, then it'll start".
Its not to say its a waste of time but when it comes time to compete on the open market, and your forced to compete apples for apples, it gets far more difficult.
It would be like you selling your oak shingles. In the time it takes you to shove your screwdriver wedge in to tilt the cant, a shingle mill has made a dozen shingles or more. Forget about the issues of red oak vs. cedar (I know some were chestnut oak which would have been a wiser choice for them all).
The point is whether or not you will think your red oak shingles are #1 viable, and #2 that you can make them _cheaper_ than a shingle mill because they are made from scrap or whatever. The simple fact is you cant. They need to be marketed to a clientele who want shingles made one at a time and are willing to pay 5-10 times the cost of anything available on the commercial market because thats what it will cost you to make them.
As always, Im not trying to poo poo your work ethic or enthusiasm.
Same thing as always, when you add up all your time and expenses honestly (without lying to yourself) it will often work out to be far less savings than you want to believe.
8/18/14       #11: sent 6 blades off for resharp ...
Rod Hays
You are right about building a truck. The reason I wouldn't build a truck is because they are plentiful. Bandsaw mills are not as plentiful. I live in West Virginia and all the hills are covered in trees. I've never seen a bandmill on the road or many ads for one. Those people who built there own sawmill are the people who are they ones people buy there sawmills from. Its all back around on how you are able to accomplish the build. I built my sawmill and their is no way I would of been able to buy one that is comparable. I've worked in a lot of machine shops that the owner would go to an auction,buy a bunch of junk and we would build a machine to do what needed to be done. This guy I worked for became very rich off of junk machines. His shop machined piston rings for GM. But in the end as long as your making a profit how ever you do it then you are doing something right. Here in WV most of these sawmills that are still in bussinss are made from junk cutting millions of feet a year. But I can also understand that many people can not build things so they are left from buying from someone who can.
8/18/14       #12: sent 6 blades off for resharp ...
I am in WV as well and there are no sawmills in WV that are sawing millions of feet a year that are made from scrap my friend. Its simply not true.
The days of someone making a fortune with an old cobbled together frick mill are gone. Production mills in this state that are sawing for national companies like Bruce Hardwood Flooring are struggling to stay alive.
Your lying to yourself if you thing cobbling together parts is going to make you rich. Its just the opposite. You have to be smart.
I own and manage a large lot of timber and there is simply no way you cant do it on a small scale unless your able to cater to a very high end client. The costs are simply to high. Making picnic tables that will fall apart in a couple years aint gonna get ya there.
If you are single with no children, sure, you can make a few bucks for your food and a case of beer and go on. If you have a wife with a good job, that helps. If you have a wife AND children, who all need food, clothing, school and college money, health care and insurance, your nuts.
Im lucky in that I have no children and all my equipment, tooling, land, is paid for. If you have a wife and children, your insane.
8/18/14       #13: sent 6 blades off for resharp ...
Rod Hays
Check out Pierson Lumber Co in Clay sometime. When there mill burn down a while back they instarlled Corley sawmill. I worked at a place that was called NATCO that most of their machines were made from junk.Google them and you might be supriesd at what they built I remember some of there machines were from 1920's. I have children and I've never had healthcare for me or my family. I've never been to a doctor in over 50 years so that point is moot, Your reasoning on shingle is moot also because I'm not trying to be a high production opertion with all their overhead they have to invest. I'm into custom work,kind of like art work. I know a guy right now who was cutting 10,000 feet a day of pallet cants on an old hand set frick. I never worked in a machine shop that had a bunch of new machines. But I understand about what you mean about production,and I have no plans of going that route. I'll leave that to those people like in places like China.I also understand that human labor is becoming to expensive,and the more you can replace human labor with a machine the more profit there could be, For example people can use simple apps that now have replaced many accountants. Then all the robots in manufacturing. CNC machines are a thing of the past now days. Back in the 80's I remember CNC machines needed someone to progam the machine. Now the machine can progam itself and doesn't need a room full of CNC computer progamers. So after 65 years I still getting by and happy with my life which means more then anything.
8/18/14       #14: sent 6 blades off for resharp ...
Rod Hays
I don't know if you heard that Coastal lumber closed all their mills and sold off all there mills in WV. The link below from 2011 says this'' Coastal Lumber Co. said Tuesday that it was going out of business, laying off more than 350 people in West Virginia and three other states.''
Article
8/18/14       #15: sent 6 blades off for resharp ...
Coastal didnt shut down. The bank came in and shut them down, lock stock and barrel. I have dealt with Pierson Lumber for 15 years, they are not running a cobbled together operation out of parts. No different than any operation they face their challenges but they employ a large staff and their own forestry operation. Dave and his wife have had every excuse to shut their operation down in the face of adversity but have persevered.
I have dealt with several in the area from Elkins to Clonch down in Dixie.
The issues is the same, they are not making their "millions" on cobbled together equipment and if your looking for the "art" market where you are your in for a rough rough slog.
I dont know of any CNC machines nowadays that are able to "program themselves" but maybe youve operated in the realm of the terminator or some advanced society that I am not aware of. Every CNC I know of, especially in the Charleston area, still requires someone sitting at a desk to output to the machine. But again, perhaps I have been operating in the stoneage for the past 20 years.
With regards to raising a family and not providing them with healthcare and money for a college education I guess I cant comment. You have the right to do whatever you see fit to your wife and children. Its not something I would ever contemplate.
I run my business like a business. I pay my taxes. I invest in my business and my community.
To each his own.
8/18/14       #16: sent 6 blades off for resharp ...
Rod Hays
The machines I am talking about is the next step up from a CNC. And I guess your definion of cobbled together operation out of parts is different then mine. Most people I know who have health care have all kinds of health problem,which you would think would be the opposite. For my health I just do what people did in the past before science based medicine came along. And college kids can get loans and grants and other things for college.
8/18/14       #17: sent 6 blades off for resharp ...
There is no "next step up" with regards to any form of machine that can program itself. It doesnt exist.
And again, to each his own with regards to providing for ones family.
Good Luck
8/18/14       #18: sent 6 blades off for resharp ...
Rod Hays
here is a MACHINE can program itself,no x y z x y z axis programming required like you would have to do on a CNC.
8/18/14       #19: sent 6 blades off for resharp ...
Good lord...
Someone still has to program the machine. Tell it what they want out of the specific shapes loaded. A programmer has to tell it what each scanned shapes specific location is. It will have a menu of pre-processed parts which are simply identified by scan and it will simply take those sets of components and assemble them into a programmed end product.
Its not like the machine is loaded with some raw steel and angle and someone says "make me an xyz" and the machine figures out how to make it.
There is no self programming other than for the fact that the software scans the parts and aligns/welds them accordingly.
Self programming would be telling a computer you want a box of a given dimension and the machine would figure out on its own what parts, the joinery details, stretcher sizes and quantities, fastener locations and quantities, and so on.
The machine you posted, as with any machine, still requires programming to tell it what to do with the parts that come down the tray.
The self programming you elude to, does not exist. We are not at Terminator level. There is still a man or woman at a computer behind every machine (likely multiples)
8/18/14       #20: sent 6 blades off for resharp ...
Rod Hays
Here is another video of a machine that doesn't need a computer progam to run.
8/18/14       #21: sent 6 blades off for resharp ...
Rod Hays
With a CNC you have to progam the tool,where it needs to go and on and on. You would have to know lots of things like the speed for the tool to run,how deep to cut and on and on. these machines can figure all those thing out without the operater having any knowage of how where or why the machine is doing what it is doing. all the operator needs to know is that do they want for the end product. no training required. if there was a sawmill like this all the operator would have to do is tell the sawmill what kind of lumber you want and it would figure out how best to cut the logs. it would be a hands free sawmill.
8/18/14       #22: sent 6 blades off for resharp ...
Rod Hays
For those who may not know what a CNC machine is,it is a machine that is a computerized numerical control machine. It takes many years of training to be able to set up and run one.
8/18/14       #23: sent 6 blades off for resharp ...
Rod Hays
here is some of my art work I built back in the 90's out of hemlock and poplar. Its down leatherwood creek about 2 miles. I believe everyone has mover out of that hollow because the coal company was going to strip it but that might of changed now the the coal company has closed up shop and laid everyone off. I sold all my timberland in 2006 before the collapse 2008. I told everyone that there was going to be a collapse but i don't believe anyone believed me. the next one will be even worse then that one. those banks that were to big to fail are now a whole lot bigger then then.
8/19/14       #24: sent 6 blades off for resharp ...
Those machines are still programmed by a human. In the case of the thermwood its simply a cnc that is supplied to you with a large library of parts already loaded to the machine from the vendor. It does no "self programming". If you need a part that isnt in the library you will have to either put it in yourself or pay some human to do it for you.
Nice art. I've been building houses my entire life. But not out of rough lumber, those days are long gone and for good reason.
8/19/14       #25: sent 6 blades off for resharp ...
Rod Hays
I guess your definition of a CNC machine is is different then mine. I myself have been building houses. I started in 1969. Bought an old grown over farm and cut it up into lots and built houses all over the place. I didn't start building out of green lumber till 1997. I really like working with hardwoods instead of pine. I like the feel of hardwood,it reminds me of walking into those old building in museums.It has that sound as you walk across the floor and that smell that hardwoods give off even as they age. Maybe other people don't notice those things but I do. I feel I am building something pass minimum building code requirements,which most build to the minimum.
8/19/14       #26: sent 6 blades off for resharp ...
Rod Hays
Here is a picture of one of the guys who logged for Pierson lumber loading my log deck with pine and hemlock back in the day I started using green lumber to build with. I always thought his equipment looked like junk. But I guess it all depends on how a person sees things.
View higher quality, full size image (600 X 450)
