Sawing and Drying
pine/spruce stakes
12/9/14
t
we currently manufacture stakes out of kd spf dimension lumber. we are considering switching to running logs then airdrying and the kilndry to set the pitch and help with ripping . we hope to get much better recovery and knot free products our finished lath is 1/2 x 1.5" x 48. the product must be dry to stay stable after cutting and painteing as well as a smooth gang rip cut we run 5000 bf per day, would use the slabs for firewood and use a baker scragg with band blades to break down the logs. the hope is that the lrf is so high that the extra work pays its way
12/10/14       #2: pine/spruce stakes ...
Gene Wengert-Wood Doc
What species?
12/10/14       #3: pine/spruce stakes ...
t
pine/ spruce alberta
12/11/14       #4: pine/spruce stakes ...
Can you run a test the left with someone else's equipment first? My impression of your resource is that 48" clears will be quite limited. Perhaps you will find that only 35 to 40 % of the pieces will be acceptable. Even the area right around a knot will tend to warp in drying, so rip yields will not be too good either. So, you might have to saw 15,000 BF per day or more...about 4 million a year. You would need a total kiln capacity of 100,000 BF. You will have a lot of green residue besides the acceptable pieces. It would be expensive to kiln dry pieces with low rip yield of acceptable pieces...you would have kiln dried waste. At first glance, this does not seem like a good idea to me.
12/31/14       #5: pine/spruce stakes ...
t
so if a person would use the knottier pieces for a pallet operation then have clears for lath? what type of kiln would a person use a dehumidification after first air dry in cant. we are gonna try a baker tri scragg maybe air dry cant then resaw or should we cut to 1.5 inch flitches dry then rip. a nyle type in a seacan? 10000 fbm per charge how long would that take? we could use standing dead logs but they would have more checking. we are currently running a 2 and btr product kdht but having to re sell up to 30% due to knot structure
