Sawing and Drying
"live edge veneer"??
2/26/15
jacob
hello everyone.
i have been asked to quote for a reception desk for a lobby that has a metal front.
[blackened steel] however glued to this the arch states he wants a "live edge veneer "
-he will choose slab.
what on earth does this mean? i can get a slab like 3'x7' -see drawing- but how do i plane/sand etc down to like 1/4"?
wont it just crack/bend etc ?
who can help?
thank you.
View higher quality, full size image (2000 X 1000)
2/27/15       #2: "live edge veneer"?? ...
Tennessee Tim
Veneer can be 2" thick...we just commonly assume the 1/16-1/4" thickness UNLESS that's what they spec'd. I don't think gluing wood to metal is going to work very well if that's what I understood. Wood at that approx width moves too much from the winter to summer MC changes. I've seen spec's Gene has posted before on the wood movement of a wood surface (glue-up or solid).
MY advice is contact architect for correct spec. Definitely define who's buying the wood top that HE choses ....THOSE prices can very greatly from one slab to another.
Keep us informed on details.
2/28/15       #3: "live edge veneer"?? ...
Gene Wengert-WoodDoc
Veneer is assumed or defined to be a thin piece of wood. So, most folks would say that 3/4" actual thickness or thicker is lumber and not veneer. At 1/2" thickness,, we might have some folks call it thin lumber and others call it veneer. Under 1/2" actual, the piece would be called veneer by most everyone.
Veneer, therefore, refers to thickness and not to the way the piece is prepared. That is, veneer can be sawn, sliced, peeled, etc.
When several pieces of veneer are laminated to make a thicker piece of wood that has the outline shape of lumber, the veneer pieces themselves can alternate the grain by 90 degrees in adjacent layers (plywood mainly). However, sometimes the grain of the veneer is parallel, such as in LVL (laminated veneer lumber).
It certainly is not clear what "live-edged veneer" would be. Perhaps the arch. wants a thin (under 1/2") top. So, as TN Tim said, get a precise definition.
3/2/15       #4: "live edge veneer"?? ...
Keith Newton
I have a friend who puts solid wood edge on his substrate, then lays the veneer on top all the way out to the edging. He then comes back and saws down grain line of the veneer. Then he comes back with a little grinding and texturing.
It looks good enough to fool everybody except other woodworkers, and the cost of veneers is much cheaper than buying the solid slab then trying to make your own.
