Sawing and Drying
kiln doors
4/9/15
Moscowman Member
I am looking to build new doors for my kiln. I currently have 2x4 doors insulated with rigid foam but have huge condensation issues. The doors swell so much when drying in the winter that I have to open them with extreme force. I am wondering if I just need a good gasket system or is it the material I made them from. They are hinged double doors. If you need more info to help me please ask. I am using an ebac dehumidification system. I just started the kiln about 5 months ago. Thanks.
4/10/15       #2: kiln doors ...
Don Lewis
If you make wood kiln doors, don't have them recessed or between the jambs. Have them overlap the opening.
4/11/15       #3: kiln doors ...
Gene Wengert
You can also make the doors very much like a barn door, recessed in the frame, heavy and use the large hinges designed for these doors and available at farm supply stores. This is the door-style that I originally used in the VT 1978 and were used in many kilns designed and built in the 60s that I was involved with. The doors were in the north wall.
