Sawing and Drying
TIG WELDED WOOD MIZER BLADE Double Hard 7/34
6/6/15
Ehzan Member
Dear Members
I am Using LT 40 HD-Electric,recently i am using my broken blades welded through TIG welding,and it can be usefull as the same as original ,is there is any problem for roller (upper blade guide)in FUTURE if i am continue with re welded blades,or any other problem for any part of the machine as well,please help.
6/7/15       #3: TIG WELDED WOOD MIZER BLADE Double ...
Ricky Member
I don't see why it should be any problems with doing that other than saving you some money.
6/7/15       #4: TIG WELDED WOOD MIZER BLADE Double ...
Ehzan Member
Thanks for your Advise,
