Sawing and Drying
cutting laminate flooring
7/24/15
Ray
I want to lay about 200' of laminate flooring and I am considering using an abrasive blade instead of a toothed metal blade. The rpms on the saw and the abrasive blade are compatible so I don't think there's a problem there. Just wondering if anyone has ever used or tried to use an abrasive blade to cut laminate. I tried on a small "sample" I got from a big box and it seemed ok. Not sure on a larger scale is all. thanks in advance Ray xdrummer61@gmail.com
7/25/15       #3: cutting laminate flooring ...
Take the batteries out of any smoke detectors that are near. I would not use your method.
7/25/15       #4: cutting laminate flooring ...
Ray
Rich, what are your misgivings on using an abrasive blade for laminate flooring. Safety?? Just wondering is all. Like I said, I tried it on a very small piect (sample from big box) and didn't notice anything other than the burnt edge. I just don 't see spending the $$ on a metla blade if a 3$ blade can do the same thing....ya no watt eye meen???
7/27/15       #5: cutting laminate flooring ...
You know you often have to rip stock when you get to the opposite side of the room, right? I really don't know what kind of saw you are talking about. Personally, I wouldn't want to breath the vapors off of burning mdf and laminate. You will also be throwing burning sawdust around the room, so what could go wrong?
7/28/15       #6: cutting laminate flooring ...
Rich, I do appreciate your comments. I didn't give the vapor thing a thought in the least. I am re-doing a camper (park model not meant to be moved) so I think I'll give it try. Once I get my pattern cut I should be ok. As for the ripping, I can cut those outside. Bad hips here so the getting up/down walk outside and back you ust not looking forward to all that. This won't be happening until 2016 but I will definitely let you know how it goes. As for the "burning sawdust", well I'm not exactly cutting pipe with a blowtorch and the sawdust is almost non-existant on the pieces I have tried it on. That's the main reason I am thinking of it. I will definitely let you know though,,,,,THAT IS IF I AM ABLE lol....Thanks again. Enjoyed...like you said "WHAT CAN GO WRONG..HEY Y'ALL WATCH 'IS!!" LOL
