Sawing and Drying
Timber Harvester 30HT25
9/1/15
al
Would anyone know what the widest cut that can be made with a Timber Harvester
30HT25 sawmill? I know it will cut a 30" diameter log but not sure if it would go through
the middle of a 30" log.
Any feedback appreciated,
Al
9/2/15       #3: Timber Harvester 30HT25 ...
rod hays
To be able to cut the middle of a 30'' dim log the wheels the blade runs on would have to be more then 30'' in dim to miss the top of the blade as the bottom of the blade that is doing the cutting.
9/2/15       #4: Timber Harvester 30HT25 ...
rod hays
My mistake,you would need 15'' from the top to the bottom of the blade to clear a 30'' log. But also the saw mill qould need to be able for the blade guides to be able to spread to 30'',which I'm sure they don't.
https://www.youtube.com/watch?v=N-ZohurbhV8
9/3/15       #5: Timber Harvester 30HT25 ...
Eric
I have this mill. It will cut about 24" width cleanly. The roller bearing mounts can be tweaked outward to give another 1" or so of clearance, if really needed. The thickest cut is about 11" before the board dragbacks interfere and prevent the mill from advancing. And I've cut a full 20' + 4" trim lengths (though it's tough to get them lined up so that the blade clears both ends -- eats up sawing time).
9/3/15       #6: Timber Harvester 30HT25 ...
al
Eric,
Can the drag backs being taken off easily to gain more depth?
9/3/15       #7: Timber Harvester 30HT25 ...
Eric
Yep. I figure it would add another 4-5" of depth to the cut if removed.
Never tried it, because I like them on there to pull the boards back when I'm working by myself.
But it doesn't look too hard either. They are hung from a rod held by 2 collars on either side. I think just removing the collars and pulling the rod will let them drop out.
I added a pic... we'll see if it gets into the thread....
