Sawing and Drying
12 volt dual feed on a bandsaw mill
7/21/14
Rod Hays
Just thought I would show you my new improved powerfeed on my homemade bandsaw mill in this video I made this morning.
9/16/15       #2: 12 volt dual feed on a bandsaw mill ...
Yve Member
Rod I just ordered the motor but what do you use for a shalf to put the sprocket on?
9/16/15       #3: 12 volt dual feed on a bandsaw mill ...
rod hays
I used a 1/2'' bolt. The sprocket has a set screw on it,but I drilled a hole through the sprocket and bolt and put a pin in it.
