Sawing and Drying
Solar Kiln Interior Paint
9/24/15
David Member
My solar kiln is coming along well, but I've had trouble finding the right product for the interior. I got some tintable concrete sealer, but couldn't get it black enough. (It's gray.) Then I got this.
http://www.homedepot.com/p/Rust-Oleum-Specialty-1-gal-Bar-B-Que-Black-Hig
h-Heat-Enamel-2-Pack-233967/204774438
But I'm concerned it might dissipate the heat. It says it "resists heat up to 1000 degrees." I have no idea what that means. It's not opened, and I could take it back. Could someone point me to a more appropriate product?
Thanks,
David
Link
9/25/15       #2: Solar Kiln Interior Paint ...
David Member
After reading and re-reading, I think I know what to do. This product might have worked, but I think I'll go with Dr. Wengert's tried and true "flat black paint."
Thanks.
9/25/15       #3: Solar Kiln Interior Paint ...
Gene Wengert-Wood Doc
The interior paint's main job is to absorb as close to 100% of the incoming solar as possible. A so end role is to act as a vapor barrier so the inside wood does not gain so much moisture. For this reason, we like one coat of an aluminum paint that will perform well as a vapor barrier, and then a top coat of flat black...maybe two coats.
Ok?
