Sawing and Drying
Moisture Content of lumber
10/13/15
John Member
I know this may be too broad a question, but what is the moisture content you all are shooting for in a new delivery of kiln dried lumber. I ask because I recently got some soft maple from a new supplier, checked moisture content, everything was 8-11%, most of it being around nine, but some boards are over ten. After completeing a few painted (CV) projects with it, I have noticed a bit more moving at the face frame and stile/rail joints than I am used to. Could the lumber be the issue? I do realize there are many other potential culprits, just trying to narrow it down.
10/13/15       #2: Moisture Content of lumber ...
Gene W. AKA the WOOD DOC would be the best for this question. That said I'm pretty sure those readings are too high. How did you get them? Do you have a good meter (over $200)? Do an oven dry test?
10/13/15       #3: Moisture Content of lumber ...
John Member
Readings were done with a ligno scanner sd, pinless type. Did not do any other testing besides that. I have been scanning every board this morning, and some are in fact 6-8%, with some at 10%. Maybe its just too much variation, and I should have caught it as I pulled boards out for machining.
10/13/15       #4: Moisture Content of lumber ...
scott
I've always wondered why people want 6-8% MC.....with inside temps at my hous of70 degrees and averaging 60% RH, that puts lumber at approx. 11% MC. I keep my shop the same that when I'm done building a piece of furniture and move it to the house it really has little to no movement. I've used my pin meter on furniture in the house ant it ranges from 10.5 to 12%, I've put a piece of wood raw, no finish, in my house for 6 months and it reads 11%. I live on the east coast and EMC seems to be around 11-12%. I wouldn't want to build anything from 6-8% MC and have it gain moisture when done....at least that's my .2 cents of knowledge on it
10/20/15       #5: Moisture Content of lumber ...
Gene Wengert-WoodDoc
We wnt to match the moisture content of the lumber during storage after drying, match the moisture content of the wood during manufacturing, and match the MC of the product when ti leaves our shop with he MC it will achieve in use. The reason is that moisture changes are accompanied by shrinker (loss of moisture) or swelling (gain of moisture). Sometimes the size change, due to grain angle or other factors, causes warp as well.
For furniture, cabinets, flooring and other wood products used inside a home or office, the moisture in wood when the heat is on will run about 6% MC (30% RH). During the summertime, the moisture will run around 9% MC. Of course, Denver is drier and Florida and coastal areas are wetter. But for most of the USA, 6% to 9% is the common range, winter to summer. Because we know that drying is often more of an issue that swelling, we target a little bit drier, so that is why we see 6 to 8% MC. Based on 50 years of experience, I suggest that a target of 6.8% MC is ideal for inside most homes and offices in North America and the variation around this value is + or - 1% MC.
Softwoods shirnk and swell less than hardwoods generally. Softwoods are often used within he walls, or in other locations that are more humid than inside the hours. Softwoods machine more poorly when under about 10% MC. Therefore, 10 to 12 % MC is more reasonable for softwoods.
As mentioned, a moisture meter should cost over $200. Cheaper meters are almost always not as accurate. Foreign made meters are notorious for having poor calibrations for North American woods. Fast repairs and maintenance are often impossible as well.
