Sawing and Drying
Doug Fir Beams
12/7/15
Myron Fry Member
I have acquired several hundred DF beams that were in a 100 year old factory that had a significant fire. Condition varies from surface burn to deep burn. I have access to a 20hp band saw mill in very good shape.
I would appreciate any tips on processing.
I am intrigued by shou-shi-ban, the Japanese wood burning technique and will save what I can off the burned face.
Most beams are 12" x 15" and vary in length. Thanks
12/7/15       #2: Doug Fir Beams ...
Dustin orth
Go over those really good with a metal detector or you will make the band mill owner very mad, or your bill will be really high for all the blades you'll go thru. Otherwise good luck!
