Sawing and Drying
Need to heat dry 57 Pieces of Teak
12/7/15
Alfredo Franco Member
Website: http://www.sandpointlogistics.com
We need to heat dry 57 pieces of Teak Wook to get them ready for export to Peru.
We need to have a Heat Dry Certificate.
We will bring the wood to any facility in Georgia , Alabama or Florida.
Please contact me at (786) 236-2684
12/8/15       #2: Need to heat dry 57 Pieces of Teak ...
Gene Wengert-Wood Doc
Why not get a certificate when the wood is imported to the USA that you can use?
12/9/15       #3: Need to heat dry 57 Pieces of Teak ...
Don Lewis
Website: http://www.nyle.com
Most of the small kiln operators do not deal with certificates for export. You may not need third party certification. Sometimes a statement with an electronic record of some sort showing the wood reached 56C for enough time. can be used. Check to be sure the level of certification that you need. If the Teak is dry and all you need is certification that it is sterilization, ask a pallet manufacturer is they could do it with a load of pallets.
