Sawing and Drying
good planers
12/19/15
weasel
I was wandering if anyone could recommend a good planer . My brother in law has a sawmill and I would like to get a planer to maybe plane boards for his customers. I need a heavy duty one to handle a lot of board feet. Any ideas
12/20/15       #2: good planers ...
Woodie
We'll all I can tell you about are Woodmaster planers. My son is building a house, 13000 sq ft, and I am doing all the finish wood and trim. He first bought a 718 with the 3 sided attachment. I've done all the wood floor, FAS white oak 12 to 16 ft long, 6 to 10 in wide. I bought a 725 unused that a guy had bought and needed to sell. The 725 is much faster and a lot heavier. I use the 725 to plann and the 718 for profiles and T&G, just finished 1000 linear ft of 7 3/4 crown. Have did a lot of shiplap v-groove white oak ceiling. The rough lumber has been kiln dried and measured between 1 1/16 to 1 1/8. I've planned both sides , the first side to thickness of 1" the other side brought the thickness to 7/8. Only thing I've had happen to either planner was a 2" chunk broke out of one of the blades on the 718. Both have done great and my son has saved a bundle.
12/20/15       #3: good planers ...
Spicolli
Second vote for WoodMaster here. I have a 718 planer with the helical head and it is a well built machine. The dust collection leaves a bit to be desired but my collection system is not top notch either. I liked the machine so much, I also purchased a 38" drum sander from them. It is similarly very heavy duty.
12/21/15       #5: good planers ...
Keith Pittman
If you have a sawmill and wanting to run rough lumber I would purchase a Newman brand planer. Pending how much footage a day would determine the model. I run over 75,000 bd/ft per day and I use a Newman Whitney 282 rough planer. For smaller volume and rough lumber a Newman Whitney finish planer single or double sided with a rough lumber set up works wonders. Any of these can be purchased on auctions for a reasonable price and will last a life time if taken care of.
12/23/15       #6: good planers ...
weasel
Thanks guys for the input think I'll go with the woodmaster
