Sawing and Drying
species identification
1/11/16
Peter Ford
ran across these small logs and really want some input on what species they are. Can someone help? The darker one is after some sanding and spray poly just to see what the grains did.
View higher quality, full size image (640 X 478)
1/11/16       #2: species identification ...
Turny
Could be several things - where are you located?
Around here I have turned both redbud and mimosa that looked like that, but I would need more pictures to be sure. Also, did you manage to collect a leaf or seed pod?
1/12/16       #3: species identification ...
Peter Ford
I'm in the central Texas area between Austin and San Antonio. Unfortunately, we got these two small logs brought to us with no leaves or seeds, etc. I think we may slab the one piece in the picture so I'll get pics of the cross grain as well. I thought it looked like canary wood except that canary wood isn't from around here. Could have been a one-off transplant in someone's yard, I suppose. But that is a long shot.
1/13/16       #5: species identification ...
Dale Lenz
Website: http://www.beautifulwoodworks.com
Just a hunch. Assuming the tree came from S. Central TX...Could be mesquite...picture of bark and wood look similar...
1/13/16       #6: species identification ...
Peter Ford
good hunch based on area and bark, but it's not. We cut mesquite a lot (about 4000 bdft a month) and the inside is quite different. Plus, this one has a kind of fruity smell when you cut it (forgot to mention that) which mesquite doesn't.
1/15/16       #7: species identification ...
First one looks like redbud, second picture guess would have been plum or peach, but the bark doesn't look right. Maybe an elm? Looks like a fast grower.
1/15/16       #8: species identification ...
Dale Lenz
Website: http://www,beautifulwoodwork.com
Can you tell us if the wood appears to be lighter/heavier in weight than most other woods? There is not much of a sapwood ring on your pictures...
