Sawing and Drying
Looking for high temp thermostat
1/26/16
ricky
I'm starting on construction on my building for my new Nyle kiln. I'm adding a heat exchanger from my OWB to help with heat as needed. Looking for ideas on a high temp thermostat, anyone here got one or know a good place to get one?
1/26/16       #2: Looking for high temp thermostat ...
Gene Wengert-WoodDoc
Grainger.com has everything.
1/26/16       #3: Looking for high temp thermostat ...
Stevem
Thermostat from a hot water heater? they are "snap" switches. New ones only go up to 140 degrees. I think older ones went to 180 degrees.
1/27/16       #4: Looking for high temp thermostat ...
Don Lewis
Make sure you need a thermostat separate from the one in the Nyle system. Usually you can use that. Check with Nyle. But Nyle also has a range of temperature controls that will do what you need, if you want to have a separate thermostat
