Sawing and Drying
8/4 W. Oak R+Q
2/23/16
Ryan Member
We just got a load of 8/4 W. Oak R+Q in from a customer. We did an oven dry on the core of the wood and have come up with 11.7, 13, 14, 11.9, 12.4 moisture contents. I know if that is the case, Im assuming the shell will be around 9ish percent. Curious if anyone knows if this moisture content is ok on the W. Oak R+Q to build furniture? If not, and it has to be redried down, is there a chance that I will ruin the wood (honeycomb, split, check)? If not, what do you think I should put in the kiln at (temp, emc etc) and how long will it take to get down?
thanks alot
2/24/16       #2: 8/4 W. Oak R+Q ...
GwnwWengert-WoodDoc
It needs to be drier. Note that when you plane or mold it, you will expose the wetter wood.
Oak is a wood that moves 1% for a 3% MC change. In most cases, the final moisture will be 7.0% MC or drier.
It is safe to put it in a kiln, as all defects expect cup occur at higher MCs.
The instructions for drying this are in Drying Hardwood Lumber. Basically, 130 F at a humidity equal to 6.0% in the lumber. I can help you with the specifics. The lumber does need to be stickered.
2/24/16       #3: 8/4 W. Oak R+Q ...
Ryan Member
Thank you
