Sawing and Drying
Redwood getting black stains right after cutting
5/13/16
james
I cut mostly redwood and have never really had this problem before. My wood is staining , black, from the sawdust nearly immediately after being cut , iu mean within minutes. The boards also seem to be ultra sensitive to additional staining from dirt bits and hard handling . We have been trying to clean the boards right away but even then they are getting blackened. I am not sure what to do.
Redwood has lots of taniin in it and it is wet . i just dont ever recall this happening so dramatically before in thousand of board feet .
Any ideas?
5/13/16       #2: Redwood getting black stains right ...
Keith Newton
James, are you using water as a blade lube? If so, you might try some Koolmist mixed in. It is a safe anticorrosive that you would add about 2 oz per gallon.
I keep and use it for grinding, but it might work for your need.
But first, you may try cutting faster, and just cutting back on the lube, if it is getting too wet. That wet slurry which gets left in the cut will have had lots of bare metal contact getting past the blade, than a larger chip which gets carried out in the gullet.
Concentrated Coolant
5/14/16       #3: Redwood getting black stains right ...
james
No lube or water , the logs seem to have enough moisture in them.
5/21/16       #4: Redwood getting black stains right ...
Gene2Wengert-WoodDoc
To eliminate iron tannate stain, put a few drops of oxalic acid on them. Check a hardware store for something that removes iron stain from bathroom fixtures and check the label for oxalic acid. It is also called wood bleach. Bar keepers friend also has it. Results such be within seconds.
