Sawing and Drying
sulphur fumigation candles
8/17/16
Lester Gillett Member
Just read about using this to get read of
PP and wanted to ask can this be used
in the solar kiln? We have a lot of White
Oak to dry and wanted to make sure its
bug free.
Sawwood
8/18/16       #2: sulphur fumigation candles ...
Keith Newton
Lester, If your solar kiln gets the temp up to 135º to the core, you don't need anything else. That much heat alone should do the trick.
The Ammonia will darken the Oak to nearly walnut, if the concentration is strong enough, but it will be superficial.
8/20/16       #3: sulphur fumigation candles ...
Gene Wengert-WoodDoc
The gas does not go deep enough to kill the eggs or insects deep inside the wood, or even shallow.
