Sawing and Drying
solar kiln
11/2/16
steveintexas Member
I'm currently finishing up the VT solar kiln project.. still have about two weeks work left. I've built it to the specs from the VT design with the exception that I put the doors in the front vs back (used 33 degree angle for the roof). I'm unsure of how to start off a load of green milled wood. Should all top vents be open? Bottom vents? Would these questions be answered in Dr. Wengert's book?
11/3/16       #2: solar kiln ...
Gene Wengert-WoodRoc
What species and thickness? Generally top and bottom are open the same. Same for left and right. Closing the vents means slower drying and sometimes this is desired.
11/3/16       #3: solar kiln ...
steveintexas Member
Making lumber from 1.25 in. Live oak, Pecan, Ash, and Elm. Have no experience drying wood, that's the reason I chose this design. I'm a wood worker/rancher.
11/3/16       #4: solar kiln ...
Live oak must be air dried first. It cannot be dried fast. Elm and ash can dry quickly, so we might open the vents slightly. Maybe 25%. Close them most of the way at the end. There are too many details to go over here, like run the fans only when daylight. There are some recent articles in Sawmill & Woodlot magazine that should help
