Sawing and Drying
twin blade sawmill idea
12/28/16
ROD HAYS
Website: https://www.youtube.com/watch?v=N-ZohurbhV8
My idea is instead of cutting the log starting from the top like they do. Build a twin blade sawmill with the horizontal blade at the bottom like everyone does it. Move the blade to the tops and start cutting from the bottom and go up/ This way the boards would drop down out of the way and you can go to the next cut . No need for having to remove the board to start the next cut. Seem like a good idea I think.
12/29/16       #2: twin blade sawmill idea ...
Gene Wengert-WoodDoc
Wouldn't the weight of the log above the blade create so much force that the blade would get pinched while in the cut?
12/29/16       #3: twin blade sawmill idea ...
To get around this, some mills hold the log by the ends, called "end dogging."
Other mills cut lumber from the sides of the log (saw is vertical) so that the sawn piece falls down and to the side.
12/29/16       #4: twin blade sawmill idea ...
ROD HAYS
here is a video of a twin blade saw mill https://www.youtube.com/watch?v=7PCPo2vXikg In the video he is going down and across. My design would start below and go up without moving over till you reach the top . After you cut ever going up you than start over at the bottom. The log would have to be held in place like on a big circle sawmill.Now that I think about it I believe this twin blade setup could be adapted to an old circle sawmill.
12/31/16       #5: twin blade sawmill idea ...
In my response, I assumed that "twin blade" meant two identical blades running parallel to each other, such as in a Skragg mill or twin band mill.
1/3/17       #6: twin blade sawmill idea ...
Yeah, suspending the log in mid-air... uhhh
