Sawing and Drying
PPB worries
4/3/17
john boland
I am in the process of building a cabin and have been cutting down ash trees to use for timber framing and sheeting the porches. I have read several posts and now am concerned about powder post beetles. I was going to have the lumber sawn on site, air dried and installed, rough cut. Is this a bad idea? It sounds like treating the wood may not work. This wood would be covered but will still be outdoors.
4/3/17       #2: PPB worries ...
Fallguy
I am not your expert, but I processed a nice old piece of doug fir in my shop and it had live pine beetle flies and larva in it this year here in Mn. I expect they thought it was spring in my shop.
Debarking and inspection is the key. I would personally inspect all the logs for beetles and debark all logs immediately after felling.
If your logs are sitting around; I'd worry more.
You could probably dip logs, but that is way beyond my expertise.
4/3/17       #3: PPB worries ...
Gene Wengert - WoodDoc
For whatever reason, ash is very attractive for ambrosia beetles when above 25% MC and then PPB at lower MCs. Borates can be used for interior exposure, but their high solubility in water (they leach out easily) means that the protection in exterior exposures is extremely limited. Heat can be used to eliminate beetles and eggs, but then the heat does not protect from exposure afterwards. I would be hesitant to use ash in exterior exposures.
4/3/17       #4: PPB worries ...
john boland
Thanks for the response. I think i will turn the ash into firewood. We are in a quarantined area in SW Wisconsin. With all the dead trees around i think the population of PPB will jump and i don't want problems in the future. I have access to some oak for posts and beams for the porch and will frame the roof with pine. Was using the ash to save some money and make use of it.
4/4/17       #5: PPB worries ...
Fallguy
Ash does make beautiful interior lumber if the logs are large enough and kiln drying can kill all the bugs. I have seen it used for floors, for boat lumber, furniture, etc.
It is generally pretty hard stuff and great for applications where wearability is important.
If you have any larger logs; consider getting them sawn.
