Sawing and Drying
Heat Treated Lumber For Intl. Shipping, Might Need A Kiln?
4/12/17
Joe Wood  Member
Website: https://woodsshop.com
So I'm shipping a gazebo kit just like this one, over to France so I need everything built from suitably kiln dried lumber, I thought.
This is all KD clear wr cedar, my supplier gave me a certificate saying it was all dried to to an average 14% moisture, but French customs is saying I need another certificate, that's this pdf I attach.
not sure my supplier can supply this other Cert, so if not could I get all these pieces kiln dried locally, brought up to a certain Temp, whatever? Anyone else had to deal with this problem before? The cedar shingles are all even kiln dried.
Even if they'd accept that,
how would I find a kiln in the San Diego area? Darn I hope this doesn't turn out bad ..
View higher quality, full size image (1040 X 812)
View higher quality, full size image (1000 X 505)
HEAT_TREATMENT_CERTIFICATE.PDF
4/12/17       #2: Heat Treated Lumber For Intl. Shipp ...
Gene Wengert - WoodDoc
The question is not if the wood has been kiln dried, but if the wood reached the critical temperature of 133 F throughout. That is, many kilns dry at 115 F maximum.
4/12/17       #3: Heat Treated Lumber For Intl. Shipp ...
In the US, the kiln operation needs to be certified to assure that the temperature of 133 F is achieved throughout the wood. So, kiln drying is not enough, even if you know that they went to 160 F in the kiln cycle...the kiln needs to be certified and records kept.
You can likely pay for fumigation at this point.
4/12/17       #4: Heat Treated Lumber For Intl. Shipp ...
Joe Wood  Member
Website: https://woodsshop.com/
Oh, that doesn't sound too bad Gene! What type of fumigation are we talking about, and would it effect the cedar at all, like discoloring, or it's taking a finish once it gets over there??
4/13/17       #5: Heat Treated Lumber For Intl. Shipp ...
In the US, fumigation is done at the port.
4/13/17       #6: Heat Treated Lumber For Intl. Shipp ...
Joe Wood  Member
Can you give me any more Info on the fumigation Gene, or point me where I can get more Info? I'm in the San Diego area.
5/26/17       #7: Heat Treated Lumber For Intl. Shipp ...
Don Lewis
Website: http://nyle.com
I think the only country in Europe that still accepts fumigation is Turkey. The rest of the EU requires heat treating for most things. We (nyle) have a customer near you that does heat treating. Send me your particulars and I will send it to them and they can contact you. It probably will only take part of one day for the whole kit to be done in a kiln. I think it can be done for less than $1 million.
