Sawing and Drying
saw blade lubrication
8/16/17
steve
i know topic this has been hashed through and through but... what are some quick, cheap, ways to put a water drip onto my saw blade? im into some hickory now which seems to be quite tough for my old Kasko saw... even with new blade...
8/16/17       #2: saw blade lubrication ...
Keith Newton
So, does this saw not have anything?
If you have to start from scratch, you can start with a 5 gallon pail, which you drill a 1/2" hole through the side near the bottom. From any ACE hardware store, you can get a rubber bushing that will fit the half inch. They also sell vinyl tubing, which you can get to fit the ID of the bushing of your choice.
A little spring clamp will work to shut if off between cuts. I'd whittle a little poorly fitting stopper for the top, to control the flow rate. more spring clamps to hold the tube so it flows where you need it.
I hope this helps. I had to replace the one on my old Woodmizer which fell apart right when I needed it, so this is what I did.
8/17/17       #3: saw blade lubrication ...
steve
thanks. this is an old saw which never had anything for dispensing lube.
11/14/17       #7: saw blade lubrication ...
Dan Member
I bought a windshield washer after market kit on line and installed it on my oscar 18 . Works great. Dan up in northern Maine
11/15/17       #8: saw blade lubrication ...
steve
thanks Dan
