Sawing and Drying
Exterior wood
9/4/17
Weasel Member
I'm getting tired of replacing my service door going into my garage. I'm wanting to just make my own door frame. Its on the north side of the garage so it gets alot of snow build up on threshold. I would like to make it out of Osage orange or hedge as we call it here.but if i can't find any Osage orange what is the next best choice
9/4/17       #2: Exterior wood ...
Gene Wengert-WoodDoc
I would use pressure treated as a first choice. Alaska cedar or northern cedar would be good in some cases.
9/5/17       #3: Exterior wood ...
Mark Hineman Member
Black Locust is more common than Osage and very decay resistant. However, finding logs large enough to saw into lumber can be a challenge.
White Oak is also decay resistant.
Both are very hard when dry, but will last a long time.
9/6/17       #4: Exterior wood ...
We make a White Oak canted 10 degree sill for all our exterior doors that don't get aluminum or bronze. I have seen 50 yr old White Oak sills, with no finish on them, that still look fine and have never moved.
No offense to the Wood Doc, but treated around here is only #3 Pine with that green stuff on it. It is so wet it is juicy, moves terribly as it dries, and is too soft for a sill. I might be my absolute last choice for a door sill.
9/6/17       #5: Exterior wood ...
Ed Member
Do not know if available in your area..
You can now buy KDAT... it is pressure treated wood that is Kiln Dried After Treatment...
Do not know how it would work for your application, but put it down on my deck and it is great..
I bought mine from a dealer for http://www.madwood.com/
also http://www.yellawood.com/resources/product-education/what-is-kdat/
has it but could not find a dealer for it..
Good luck on whatever you choose...
