Gene thank you for your message. If there is a more appropriate place for this post, please let me know so I can move it there.
When I first started building epoxy-plywood stitch and glue boats, I was sold on the epoxies incredible ability to seal wood and make it innate.
However, the reality is that I have actually found this quite hard to achieve; and I now wonder if epoxy is more porous than I thought.
Take this current boat for instance. It is made with three plywood panels on each side - a hull panel, a lower side panel and an upper side panel that is epoxy glued to overload with the lower side panel by 6 inches. The outside is sheathed in biaxial fabric and epoxy, as was the inside. All screw holes were overdrilled, filled with thicked epoxy and then redrilled. Essentially "watertight"...
My bad epoxy/ delamination issues were limited to the inside of the hull and to the bottom and lower side panels. I know this because that was all sheathed in one day, with one certain batch of epoxy. All the rest was a different brand and done at a different time.
The "bad bits" have been completely cleaned, sanded and scraped to bare wood and left under the tarp with a dehumidifier inside.
My pin moisture meter is telling me ambient here (I am in the tropics) is about 16%; but my hull and lower side panels are now down to about 8-11% under the trap and dehumidifier. (This is similar to test pieces I put in my dehumidified room in the house).
When I tested the hull with a Pinless sensor before I started dehumidifying it, it was telling me that the relative humidity was much higher in the lower side panels and the bottom panels; now it is telling me it is the other way round. At this stage this is good news - the dehumidifier is working and I am drying the bottom panels and side panels which had water ingress.
However, it is also telling me that the upper side panel - which is still "sealed" with fiberglass and epoxy on both sides and has intact paint - and which was built in a place with a much lower humidity - has "quite" a high moisture content...
So I begin to ask myself - how is the moisture content in this "sealed" panel so high?
Does the boat living at a higher ambient moisture mean that eventually water does diffuse through the epoxy?
And if so, can sealing the rest with epoxy - as best that I can - ever really be trusted to stop it reaching that 22% mark that might cause rot?
