Sawing and Drying
L200M problems
12/25/17
Peter Member
I have a new L200M that I am running its second load thru. I believe it has not been extracting moisture. Temps in kiln have been 90-95 dry bulb. And 90-94 wet bulb.
It has been running since 12/11, and in the beginning, the wet bulb was above the dry bulb. I trimmed the wick, and that fixed that.
However, the back of the kiln chamber is building moisture, and I pulled the drain hose, and no flow. I then pulled the filter, and the condensation fans are warm and dry, and drip tray is dry.
It has not been pulling moisture out at more than .3 to .5 percent per day, if that. The compressor icon says it is on , but appears not to be operating
I have looked for a troubleshooting section in the manual, there is none.
Any help greatly appreciated!
Thank you.
12/25/17       #2: L200M problems ...
Gene Wengert-WoodDoc
There is no way that the wet bulb can be hotter than the dry bulb, no matter what the wick is doing. Take the wick off, dry the wet bulb and then it will be like the DB and should be the same temperature as the actual DB.
Next, the compressor on light only means there is power and not that the compressor is running. With the potential DB and WB issue, it is likely that the compressor is not compressing very often. Depending on your controls, sometimes the compressor comes on when the WB actual is three degrees above the setting and runs til you get the setting. With you apparent settings being so close, the system gets confused.
There is also a thermal reset button on the motor that may be popped.
To check it, set the DB at 115 and the WB at 90 for a few hours and see if it is running.
12/25/17       #3: L200M problems ...
Peter Gagliardi Member
Gene, thanks for the info. The wet bulb sensor was indeed reading over the dry several times, even though it is not possible. Believe me, I scratched my head on that one. I think I found the answer, as you were responding, and it was as you said. I opened up the right side of the unit, while it was off, and there was a reset button on one of the lines coming off the compressor. Pushed it, closed it up, and let the machine set in the off position for 15 minutes, and turned it on.
It was outputting water in about 10 minutes.
Thanks again.
