Sawing and Drying
Keeping Lumber Dry
3/27/18
Vic
Not really sure where to post this, but I know Dr Gene is here at times, so....
We have a moulding shop. One of our problems is keep our raw lumber form gaining MC from sitting around too long. So we spent quite a bit of money on a nice, insulated, heated building to store our KD lumber along with trim that is awaiting shipment. We build and started using this building last fall.
During the winter this was no problem as we keep the building temp about 20 deg's or so above the outside temp. But what about this summer when we can't and don't want to run the heat. What can I do to keep the humidity down in a 6000 sf building when the outside temp is 95 and the RH is 85 to 90%??
Any ideas besides a humongus AC??
3/28/18       #3: Keeping Lumber Dry ...
Gene Wengert-WoodDoc
If the lumber is dry and the building is well built so it does not let moisture into the building, then all you need is one large, or maybe two, dehumidifiers. The air itself has very little moisture...maybe 1 cup for 5000 cubic feet, and you only need about 35% RH. You will need a small fan to stir the air.
3/28/18       #4: Keeping Lumber Dry ...
I should have added, get a DH from a big box store and get the extended Warrantee.
