Sawing and Drying
timbore verses boracare
5/28/18
Jonathan Cook Member
From a little reading it sounds like boracare penetrates dry wood better, but timbore is much cheaper. I have a bunch of cants yellow pine 6x8 up to 12x12 that have been stickered in my barn for years. I plan to re-cut most of them to cut any twists out then spray them with boracare or timbor and then put a finish on them before making a timber frame. Can I get by with timbor since it is cheaper. any recommendations on a finish for them? Best place to purchase timbor or boracare?
6/6/18       #3: timbore verses boracare ...
Gene Wengert
Please read the label for both. Note that both require substantial dilution with water. Note that both have human and environmental health hazards. Note that the active ingredient is the same for,both.
Timbor
http://www.pestproducts.com/products/timbor-label.pdf
This is 98% borate- -disodium octaborate tetrahydrate .
Boracare
http://nisuscorp.com/images/uploads/documentsspecimenlabels/label_sds_boracare.pdf
This is 40% borate- -disodium octaborate tetrahydrate
6/8/18       #4: timbore verses boracare ...
Bill Smith
Website: http://www.esf.edu/nekda
Boracare penetrates into, especially drier, wood better because it has a certain amount of glycol co-solvent compounds which help keep the active hydrolyzed boron soluble in moisture and thereby still diffusible. So if your timbers have been drying on stickers in your barn for years, boracare is preferable. However if the timbers are dry, and will be used in a timber frame where they will remain dry, why is wood preservative necessary? Once the wood surface is dry after application of either timbor or boracare finish can be as if the surface was untreated.
6/20/18       #5: timbore verses boracare ...
Mitch Suber  Member
Website: subercustomshutters.com
I started recently treating our exterior shutter components with Timbor. I haven't been using it long enough to be able to report anything in regard to results. The Timbor does dilute well, applies easily. Surface residue is minimal afetr drying. All surfaces take our primer and paint the same as before. Im not sure what quantities you need, but I bought my first bags off of Amazon.
6/20/18       #6: timbore verses boracare ...
Thanks all for the response. Mr Smith The treatment is for powder post beetles (or some other small boring insect) that are in some of the cants. Should have mentioned that
Dave
