Sawing and Drying
Does 150 year old wood become permanently dry?
7/20/18
len huffman Member
Does wood that is 150 years old respond to changes in relative humidity in a similar way as wood that is 25 years old? Some say old wood becomes hard as a rock and never changes.
7/21/18       #3: Does 150 year old wood become perma ...
Gene Wengert-Wood Doc
No, unless it has a moisture barrier on its surface or is imbedded with some chemical that stops moisture changes or has some other internal chemical changes. However, because of the hysteresis effect, "old" wood sometimes appears to be less sensitive to moisture change than "fresh" wood.
