Profile for beaded column??? -- 0 --
10/8
I need to build a 8" dia wood column. I would like it to be beaded. Hollow, made like a old wooden barrel. Probably around 2 inches wide and 10 pieces to make the 8 in column. I would run the pieces on my moulder.
So, what I'm looking for is a profile or pattern for the individual profile to make up the column. Sort of like a reeded or fluted inside radius corner. But several put together to make a circle.
Mirror Ref almost has what I want, but looking for the exact pattern.
Anyone help??
10/9 #2: Profile for beaded column??? ...
Are you looking for a birdsmouth cutter for the stave edge, or the reed cutter for the face of the staves?
10/10 #3: Profile for beaded column??? ...
If Russ has something close then email or fax him a drawing of what you want. I am sure he can get you what you need. His drawings are awesome and his willingness to help a fellow woodworker achieve a high standard of craftsmanship is second to none!!!
The amount of information he knows is unreal!!
10/11 #4: Profile for beaded column??? ...
Thanks for the responses.
I was in a little bit of a time bind, so I decided to try it myself in TurboCad and it just came together.
In fact we made the sample pieces yesterday and they looked and fitted fine.
Now if I can just figure out how to glue, clamp, hold, place them all together.
thanks again
10/16 #5: Profile for beaded column??? ...
Staves for smaller wood columns are typically flat boards with beveled edges. These are laid out flat along side each other with their outside edges taped. Then they're glued, rolled up into a cylinder and band-clamped. The resulting octagon is then turned on a lathe to a proper entasis and fluted or reeded.
Completed cnc staves (including fluting or reeding) and then glued together, sounds backwards to me.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
