Solid Wood Machining
Weinig Profimat 22
11/4/13
Kim Vedros  Member
Website: http://www.archturnings,com
I'm looking at a profimat 22 to purchase for s4s work. On the high end, I'm hoping to run 12/4 by 8" to square up all sides. Do you think there would be any problem doing this?
11/5/13       #2: Weinig Profimat 22 ...
Russ
Website: http://www.mirror-reflections.com
Kim
That would depend on the horsepower on the machine, Look at the motor tags on each motor or look inside the electrical box, it is written in kilowatts if you times the kilowatts by 1.36 you will get the American horsepower.
Also take some time to see if the bedplates are not worn, its been awhile since they made the p-22. This will affect id you get a square product or not, simply remove the left spindle chip breaker or hood assembly, the bedplate under these areas should be at factory specs, take a precision straight edge run it to the inside fixed fence, you can measure with a feeler gauge or use flashlight to see any wear it its there at all.
Best of luck
Russ @ MR
11/5/13       #3: Weinig Profimat 22 ...
Kim Vedros  Member
Website: http://www.archturnings.com
Thanks Russ
Will check
