Solid Wood Machining
Freeborn C&S Set
11/18/13
Jim Henko
I picked up a used 6 piece C&S set (smaller 3/4 Bore type) and had it sharpened. The fit is rather loose, and I think it is on the tounge side. Does anyone know how much it costs to have the bores adjusted on these 6 piece sets to improve on the joint fit? Also, how much does a 6 piece set sharpening usually run in your area? Thanks!
11/18/13       #2: Freeborn C&S Set ...
Bruce H
What fits loose? the machined joint or the cutters to your spindle?
If it is the machined joint you can get a shim set from Freeborn and adjust the fit to your liking.
11/19/13       #3: Freeborn C&S Set ...
JeffD
Each time a set of cutters gets sharpened it's going to change the fit of the joint. In order to make the joint tight again you'll need to make your tongue just a bit thicker. As Bruce mentioned you can get the shims from freeborn, (or other sources), to shim the cutters and improve the fit.
good luck,
Jeffd
11/19/13       #4: Freeborn C&S Set ...
rt
All tooling set loses a little of their fit each time they get sharpened just because of the relief angles ground into the cutters. One thing is to use a reputable grind shop, if they go at it way to hard or take off more on one cutter than the other your fit goes to crap. Cheap facing grinders or inexperienced shops can take a good set and turn them into junk real quick.
Freeborn can re-tip when the finally get too bad, but it is not cheap and usually just under the cost of new.
