Solid Wood Machining
3 phase rotary converter for weinig p22 & dust collection
1/12/14
tlkellar Member
need info on sizing & installing 3 phase rpc for weinig p22 5 head moulder & 10 hp dust collector the full load amp for moulder is 130 i know i need at least 30 hp for rpc i have 200 amp service in shop .does this mean that 130+dust collector amps will have to be fed to rpc to satisfy load seems like alot of amperage to send to 30 hp motor
1/13/14       #2: 3 phase rotary converter for weinig ...
Bruce H
Typically rotary phase converters are rated by the largest single motor they will start and the total number of combined HP they will run. In your case the Weinig has several motors, your converter needs to be able to start the largest and run the total HP including the dust collector. In general the converter will run three times the HP of the largest single motor it will start. All of this needs to use less than the 200 amp service panel you have, add up the amps on the motor name tags.
1/15/14       #3: 3 phase rotary converter for weinig ...
phil v
I have a similar situation I run a 4 head scmi with 18hp heads on a 25hp phase converter with 10 HP dust collection and the guys run another 10 HP phase and run a number of other machines at the same time so that 200 amp service is not a problem
