Solid Wood Machining
jointer question
2/18/14
Mark Member
Has anyone purchased a new jointer table/cutter without any kind of stand or motor? My jointer isn't cutting off a consistent measurement and how I have a jointer situated in my shop doesn't bode well with a jointer that's on a stand. I'd like to replace the table/cutter assembly and keep my belt driven motor. Thanks.
2/18/14       #2: jointer question ...
Ned Flanders Member
What is a table cutter?
What kind - make, model - of jointer do you have?
2/18/14       #3: jointer question ...
Mark Member
I've got a Jet JJ6 6" mounted to a wood table, pully drops down to a motor on a pivot hinge so the weight of the motor provides the tension on the belt. Ideally I'd like to replace the jointer and keep the same motor setup.
By table/cutter I mean "the jointer" without a motor or stand.
3/13/14       #4: jointer question ...
Rick L
You will most likely pay more for a bare bones jointer. Machines are packaged with motor and stand for best price. I think you are being silly to go this route. Obviously a hobby woodworker.
