Solid Wood Machining
lock miter cutter
3/1/14
Gary
Does anyone know of a lock miter type shaper cutter that aligns the joint for assembly but does not require one side of the joint to be run vertically through the shaper?
3/1/14       #2: lock miter cutter ...
cb
Freeborn has one that you run both pieces horizontal on shaper. Than dado one of them on the table saw.
3/2/14       #3: lock miter cutter ...
Max Neu
Does your spindle tilt?If so,it can be done with a set of custom cutters.
