Solid Wood Machining
miter saw for crown molding / toe kick
3/5/14
Mark
I've got a 12" bosch dual miter saw and notice when cutting toe kick or crown molding the curvature of the blade is noticeable on a 45 degree cut. Would going to a 8 or 10" saw reduce that curvature?
I'm looking towards more of the best crown molding saw vs. the best all purpose. Is smaller better for crown molding?
3/5/14       #2: miter saw for crown molding / toe k ...
Buy a better blade. The Forrest Chopmaster's 12" blades do not deflect.
3/5/14       #3: miter saw for crown molding / toe k ...
Mark
I'm using a Frued Diablo now and it works nice for straight cuts but soon as I put an angle to it I'm not satisfied with the cut.
3/6/14       #4: miter saw for crown molding / toe k ...
Diablo is Freud's cheap line of blade.They are also thin kerf. Cutting across the grain versus diagonally across it is different. Miter cuts can cause more deflection. Buying a better blade costs alot less than buying a new saw.
3/6/14       #5: miter saw for crown molding / toe k ...
Mark Member
I'd agree with you. I noticed that too on my Freud blade on my table saw, Even ripping plywood I noticed deflection. Somewhat limited in quality in the selection at the retail level in this area so I switched to a Frued diablo blade made for ferrous materials, 56T and a nice thick kerf. Way better results, nice clean cuts on the ripping or crosscut on the table saw.
New Forrest Chopmaster blade should be here tomorrow just in time for a weekend installation. I'll post my review.
Thanks,
mark
7/2/14       #6: miter saw for crown molding / toe k ...
Charlie L Member
I've been using FS tools blades for a while. I'm very happy with them http://www.fstoolcorp.com/Products/Saw%20Blades.aspx
