Delta 3 hp shaper -- 0 --
5/3
Website: http://davidjklenk.com
I need to change the bearings on a 3 hp Delta shaper. Before I start I thought I would check to see if anyone reading these forum posts had done this task before and if they had any advice for how I can do it? Do I need to buy the bearings from Delta or can I get them from McMasters or MSC? Any thoughts would be helpful. Thank you.
5/4 #2: Delta 3 hp shaper ...
Delta has not been able to ship parts for over year now - due to a sale and confusion and loss of desire to do business or some such nonsense.
Fortunately, bearings are easily available form a number of sources. Use the existing bearing to get the numbers. I like using Bearings Inc, a local outlet, since they can advise me on stepping up a grade or two, or improving life or performance.
Below is a link to a small shop that makes and supplies the parts for the older Delta shapers (43- 363) that have spindle cartridges with interchangeable spindles.
Delta Parts, Cartridge Type Spindle
5/4 #3: Delta 3 hp shaper ...
Prices certainly are more than reasonable. Too bad he doesn't offer Powermatic.
5/5 #4: Delta 3 hp shaper ...
Hi David, thank you for the lead. I'll start taking the shaper apart this week and contact Bearings Inc. for the new parts. This was a big help.
5/5 #5: Delta 3 hp shaper ...
FWIW I believe the Delta cartridge bearings are pre-loaded, so a little more involved to change them than some more basic situations. If it's an older machine you may want to check out OWWM as they have several threads on changing the bearings on Delta shapers.
good luck,
JeffD
5/6 #6: Delta 3 hp shaper ...
Yep, what JeffD said.
OWWM, and if you can get a response from Robert Vaughan, you will have it made.
5/6 #7: Delta 3 hp shaper ...
The problem is that it is only 14 years old. the OWWM website says they only discuss machines more than 20 years old. It gets worse, it is a Platnium Edition. I'm not sure just what the difference is between these and the standard edition but it seem to be more complicated then just changing the bearings like I would on a unisaw or 8" jointer.
5/6 #8: Delta 3 hp shaper ...
My suggestion is not going to work for that newer type of shaper. And as JeffD said, those older shapers have the preloaded bearings in the cartridges. The link is to a small shop that offers those cartridges as rebuilt units, as well as the related parts.
The newer Delta bearings should be easy to pull out, though you are on your own if the OWWM site doesn't have parts diagrams of shapers similar to yours. Delta things did not change much over the years, so it is possible to see old diagrams that still describe recently produced machines. Be sure to know of a machine shop that can pull the old and press the new properly, in case it takes that operation.
5/6 #9: Delta 3 hp shaper ...
The Y2K model with the interchangeable spindle uses the 6204LL size bearings.
Try Accurate bearing for that size. About $5.00 each. I'll use Nachi or NTN for that application. There are better bearings, but that gets into a world of technical that I don't want to go do.
OWWM welcomes and encourages owners of USA-made machinery and your Delta clearly is that. Another qualifier is if this USA-made machine is now discontinued which your 43-375 would be.
The rub for age comes to posting things on Vintagemachinery.com, but I think there the discontinued rule works.
a couple of conversations that may be helpful
(cut and paste)
http://owwm.org/viewtopic.php?p=346388#346388
http://owwm.org/viewtop ic.php?f=1&t=42945
5/7 #10: Delta 3 hp shaper ...
Thank you David and Bob. With this information and the places to get the bearings I feel comfortable taking this project on. I'll post photos and information once it starts.
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
