Solid Wood Machining
western red cedar checking
5/28/14
Kevin Member
I am in the middle of cutting some rafter tails out of 2x WRC for a local landscaper to use in a pergola. Moisture content is 12-15% which apparently is common. My problem is, after the scroll shape is cut, the rapid drying of the end grain is splitting like crazy. Is there anything I can do to reduce this? There will be some type of finish on them, but it hasn't been decided. Thanks.
5/28/14       #2: western red cedar checking ...
Kevin Member
Just check the MC of some more boards. They are up in the 20 to 40% range. Is this what is causing the most severe checking?
5/29/14       #3: western red cedar checking ...
Correy Smith
Yup that's the cause of your checking.
20% is near the 19% for construction dry.
40% is still green.
You could check each board before you buy it or sticker the whole pack and let it acclimate or a few/several weeks first.
End sealing would be practical but the sealer would need to be compatable with the finish. So wax is probably out. Unsure if any oil /stain finishes typical on outdoor woodwork would slow moisture loss from end grain like a polymerized oil or wax coating like Anchorseal green wood sealer. Latex paint works a little but not as good as wax.
If you can kiln the material to under 20% that would help alot. Or return the wood and buy from a source that has KD material for you job.
6/18/14       #4: western red cedar checking ...
Gene Wengert-WoodDoc
The extent of checking that you are seeing (based on your note) means that the wood has likely been damaged before you got it. I small amount of drying from 20% to 12% MC for example, would not severely check the wood. In most of the USA, the outside average humidity is 12% EMC. At 12% MC, the wood has gotten quite strong and so developing new checks at lower MCs is very difficult. If indeed these are news checks, then we know for certain that checks are created by the loss of moisture....more than just a few percent. Note that a few pieces of cedar will be extremely weak due to bacteria that get into the living tree. Such pieces will also be much higher in initial MC than normal. The color is often much darker too.
