Solid Wood Machining
Planer blade life
6/20/14
Aaron Member
I have read in numerous posts about how heat is the enemy of planer knives, as well as the many causes of excess heat. I would like to know if heat damage from running blades too long (i.e. until really loud) or improper sharpenings will go away at the next sharpening, or does the heat damage deep into the blade where it will reduce knife life for many future sharpenings?
Also, in another planer with a spiral head, will heat damage affect the other surfaces when you go to turn the sets?
7/3/14       #2: Planer blade life ...
Rick L  Member
You will not reach temperatures high enough to do any damage to the steel or carbide. You can look up tempering on steel. Ask your Sharpening service about more details on this. You are making more of this heat thing than necessary.
